I had to mount two MAP sensors. The MAP sensor tells the electronics what the manifold pressure of the engine is at any given time. One sensor, the black one on the engine side talks to the Electronic Ignition for the bottom spark plugs. The one mounded inside the plane talks to the GRT onboard computer.
